tbi 350 to carb??
sdime2372@yahoo.com's avatar
tbi 350 to carb??
jumbo's avatar
jumbo
The wiring on my tbi is beyond fubar'ed, I'm calling Uncle and going carbed. At least for now, just to get it to run. So here's the skinny:
I have a 1989 GMC Suburban with the TBI 5.7L motor, with the 700R4 tranny (supposedly). My father in law has several carbed 350's at his house, he said i could use whatever i need off those. I know i'll need the intake (are there different intakes that fit the 89 block, or are they all pretty much the same?), a carb, HEI distributor, and fuel regulator to choke down the fuel pressure to carb. Anything else? I've done some research online and found some people that say i need a TV Cable or something? or a switch to lock the tranny? what up with dat?? I know it's not a 4L80-E because they only offered those starting in the 91 burb, so i know it's not electronic. Am i missing anything else? Please don't start with the "why go carb, you gotta keep that tbi" threads, as i said, the wiring for the tbi is beyond fucked (missing plugs, missing plug ends, relays on firewall with no idea what they're for, nothing labeled or color coded, etc, etc.), i just want the damn thing to run for more than 30 seconds so i can enjoy it for a little bit. I'll probably eventually rip out ALL the wiring and go with a new painless tbi harness and complete vehicle harness, or something, i just need it to run, like NOW! Any help will be much appreciated.
baggedbmy93mazda's avatar
baggedbmy93mazda
i have a complete harness, ecu everything, its out of 87 k5 blazer...ill let it all go if you wanna stay tbi! and are interested.....
cookiemonster13's avatar
cookiemonster13
89 is the non vortec head so a standard 350 intake will work. you need an HEI dizzy, a carb (i would suggest a 600 edlebrock), a kickdown (TV) cable for the transmission if it is a 700r4, you will also need to jump one wire on the transmission to another terminal and get power to a third out of 4 terminals so the converter will lockup, and get your fuel pump regulator and you should be ready to ride.
http://www.hotrodders.com/forum/700r4-lockup-wiring-diagram-112798.html
there is a wiring diagram for the lockup solenoid.
baggedbmy93mazda
yeah i was looking for that.....i did this a few years ago...dad walked me through it... i was looking for info...^^^^^^yeah what he said....lol
