HELP... Brake Lines for a 66 to a 1984 C10
stockfloored85@aol.com's avatar
stockfloored85's avatar
stockfloored85
I put 1984 uppers and lowers and my 66, put on drop spindles..... WHAT rubber brake line will bolt right up to my 66 hard line and 84 caliper? I was told a monte carlo rubber line.. but what year?
twotonemaz (johnny)'s avatar
twotonemaz (johnny)
David if you knew what thread and style seat was on your hardline I could get you some adapters from work and run you some stainless braided lines.
tre5's avatar
tre5
Do a search on 67-72 chevy forum. There is info on there that will tell you the size of the inverted flare fittings on your stock brake lines on the frame and the lines from the caliper on the newer years. Then you can just get an adapter fitting and be done. Or you can just figure out the fitting size on the factory lines on the frame and run the braided lines.
