breakin ball joints..need help!!!!!!!!!!!!!!
nickm210@yahoo.com's avatar
baggedrado210's avatar
baggedrado210
OK SO I HAVE A 2000 SILVERADO LAYED OUT ON 22'S...I HAD A SHOP INSTALL SUM CHASSIS TECH(i no their cheap) DROP SPINDLES AN i have been havin problems wit snappin ball joints n half.....I HAVBE BEN THREW 5 SETS WITHIN A YEAR...I BOUGHT CHASSIS TECH RECOMMENDED ONE AN AUTO ZONE ONES BUT DEY ALL BREAK....IM THINKIN ITS CUZ I NEVER GOT AN ALIGNMENT AN GOT SUM CAMBER ISSUES.....I VALUE UR INPUT AN NO RESPONSE WILL GO UNNOTICED...THANX
jeebus @ mmw's avatar
jeebus @ mmw
pictures will help.
Is the ball joint shaft breaking? or is it snaping out of the socket at the top.
Chances are, the actual ball joint shaft does not fit inside the spindle correctly, and it has some wobble room, and as you drive it fatigues the material enough to make it fail.
post up some pics of the snapped joints.
Taylor
rolnlowdotcom
Im shure your upper ball joint is binding because the shame drop spindles are 2-3 inches taller than a mgaughresbundalandibad drop spindle with the spindle being to tall it binds the ball joint when layed out. So the 100 dollars you saved is now gona cost ya because you need a set of western chasis or mcgaughys they both sell a great product. And when replacing your spindles get you self a set of the good napa ball joints the ones with the blue rubber boot they are worth the money. This will help the camber a bit too
phat phabrikationz's avatar
phat phabrikationz
Chassis tech spindles are pretty close to factory specs with the ball joint hole tapered the opposite direction. They inform you to swap upper control arms to opposite sides upside down and turn lower ball joints upside down.
This will snap the ball joints due to binding.
Cure: put everything back to stock and install McGaughys spindles and never have an issue again.
BK2LIFE's avatar
BK2LIFE
why dont you contact chassis tech and ask them? maybe they have a new spindle out that they could swap you to take care of the problem? or they might have a suggestion as to what the problem is, and a cure for it.
