YORK COMPRESSOR CHECK VALVE INSTALLATION LOCATION?
slatersbro@yahoo.com's avatar
SLATERSBRO's avatar
SLATERSBRO
Edited: 4/25/2011 10:44:40 PM by SLATERSBRO
I WAS INSTALLING MY YORK AND RAN INTO A SNAG. I BUILT FITTINGS AND BUT REALIZED THAT I INSTALLED THE CHECK VALVE RT AT THE COMP. WILL THIS BE A PROBLEM? I HEARD THAT THESE THINGS GENERATE UP TO APROX. 200 DEGREES FAHRENHEIT. WILL THIS DAMAGE THE VALVE? I HAVE ALWAYS SEEN THEM INSTALLED AT THE END OF THE BRAIDED LINE. ANY HELP WOULD BE APPRECIATED.
unusualfabrication's avatar
unusualfabrication
I have my check valve 12-18 inches after my York and yes they do make some heat.
Slappy Mc Nasty's avatar
Slappy Mc Nasty
i have my check valve about 2' away. heat is any edc's enemy and that one item is one i wouldnt risk your air ride too
Marcos_65's avatar
Marcos_65
I ran my check valve near the tank just in case the line breaks it will not lose tank pressure.
NorthwestS's avatar
NorthwestS
Mines at the tank also
cajuntaco's avatar
cajuntaco
Edited: 4/26/2011 1:27:43 PM by BagD72Chevy
I have one 3 ft from compressor, so the Square D pressure switch can dump the head pressure. Then I have another from the main line to the tank at the back, and one from the tank to the valve manifold. I want to make sure I don't lose air while towing.
SLATERSBRO's avatar
SLATERSBRO
Thanks for the info guys! I hadnt thought about running the check valve at the tank thats a great idea. What I was trying to get info on was if the checkvalve could handle the heat. but all the info is great I think I will get my hands on one more valve!
Marcos_65's avatar
Marcos_65
Yeah man! Cheap insurance!
