Car keeps dropping. Help
adam_clark__@hotmail.com's avatar
artsar's avatar
artsar
A friend of mine was hitting switches in my car today and kept lifting the front after it was maxed out and now one of the front corners won't stay up. If I close the slow down I can still drive it, but I can't seem to fix it. I took the coil off and tapped the block to see if maybe something was stuck. Nothing has worked so far. Did he break the dump? If so can I just replace the stem and be done?
Any other ideas?
zaccanti's avatar
zaccanti
o rings still good?
I
IGotIssues
Could be the dump seal. Back in the day I blew an outer dump seal, and it leaked in the trunk. If you don't see fluid anywhere, check the inner dump seal on the stem. What kind of dumps are you running?
artsar's avatar
artsar
Theres no leaks on the ground or anything, its just leaking back into the tank.
I will check the stem, I thought that might be the problem... damn
AON-JAMES's avatar
AON-JAMES
Check the inner o-ring for sure.
AON-4PumpedCL's avatar
AON-4PumpedCL
If closing the slowdown fixes it from falling, then it's your dump seals.
artsar's avatar
artsar
Yea turns out one of the O-rings got ripped and the other got pushed off the stem, luckly I had random dumps from before and use those to fix it. I never took a dump apart, learn something new every day.
rastaryan
yea i kinda have the same problem when i hit the front to go up the passanger side sits lower then the other side , any ideas how to fix it? i got to show time pumps with 6 batterys on a 64 impala
