how to lay a chevy 94 on the frame with 24s not body dropped
josers91noma
my buddy has a 1994 chevy silverado he had 20s but is going to go 24s, will he be able to lay on the frame if he buys spindels and comtrol arms or is their some more custome work to be done like cutting the frame or moving the arms mounts thanks if u have pics would be best
bigjon's avatar
bigjon
Simple trim till it lays my tahoe is bodied on 24's
retro dime's avatar
retro dime
You're going to also have to tub the firewall, notch the tie rods, and relocate a couple things under the hood
josers91noma
its tubbed so everything that was on the way was moved already he was wondering if he is going to need arms or modiffy the arm mounting points or notch the frame for arm clearance or anything like that thanks
dawgpimp's avatar
dawgpimp
use a tape measure. put the truck on stands. take the 20'z off. remove the shocks, bags, or whatever is it the way. find out what diameter the 24" tire is. measure the frame to the ground. add that to half the size of the 24. jack your spindle up until it binds or you reach that measurement. modify the suspension accordingly. if simple math is too hard, then back away from the truck.
mindlissmetalfab's avatar
mindlissmetalfab
you can lay 22s on those trucks with stock spindles by pie cutting the frame and notching for tie rods. So 24s should only mean you have to add drop spindles.
