rides
market
More
Events
Gallery
Wiki
Store
Threads
Rides
Market
Events
Gallery
Wiki
Store
Browse
Mini Truckin General
\ how to cut a square hole?
General Discussions
views 255
replies 7
following 8
slow50
i need some ideas on how to cut out a square hole for some rocker switches. the only thing i can think of is drill a hole the square it up with a die grinder. or cut it on the mill maybe? but id still have to square the corners.
BK2LIFE
first answer, a square drill bit..
seriously though, both your answers are correct
THE LOW RANGER
DRILL IT THEN USE A GOOD FILE AND THAT SHOULD DO THE TRICK
h2omelon(nick)
Dremel tool
Slappy Mc Nasty
is it in plastic? ive used a dremel w/ a cut-off wheel before. if you go slow, its cake. a small drill bit, then using an air saw will work too
tuckinlugs06
id use a body saw after i drill a hole o start
mindlissmetalfab
lasers
kaoss
Any one in your area do water jet cutting?
