Chevy/GMC Trucks \  Choppin block arms ?
views 973
replies 10
following 7
groundedbigbody   +1y
Wondering if any of you guys are running choppin block arms and also running a 24x10 wheel on a obs and how low can you ride and turn I really want mmw arms but would like advice on which way you guys would go
bigperm   +1y
hey chad.
the choppin block arms are super nice, but i dont know if they can be order in shorter lengths to help turnin radius.
i know mmw arms cone w/ uniball uppers, and i think you can get them 1" shorter length, which will help you turnin low, but you gonna have tub the bejeezus outta your firewall. keep us posted with what u decide!
groundedbigbody   +1y
My firewall is rubbed for 26s
sawyerlow20   +1y
whats up chad, burban looked good at showfest its came a long way since nick had it in tennessee and motor still sounds bitchin. in my opinion i would go with mmw i have a 94 fullsize bodied on 9 1/2" wheels with 4" backspacing im using the choppin block arms and just to clear the wheels i had to remove the knockouts all the way on the top to get it to lay and you can get the mmw up to 1.5" shorter if you go that much shorter it might have a little effect on lift but i dont know i would call mmw i hear they are good with info. im not bad mouthing the choppin block arms there good quality but as soon as i get the cash up im goin with mmw for my truck and plus they are just badass looking.
jeebus @ mmw   +1y
Just for the record, i can do them any amount you need shorter. 1" or .9375" or even .716434" anything you want ... there CNC cut, so i make them to order for your specific back spacing and wheel width. Each set is set to your specs.
a lot of people done realize that, so i like to make sure people know that, its a nice way to make sure your getting a good setup for your arms.
The chopping block arms are nice as well, they are out and on a ton of vehicles, they look great. I thought there was just a set in the classifieds section for a good price...
Taylor
groundedbigbody   +1y
Thanks Taylor I already had talked to you about them over the phone and the info you gave was awesome I'm concerned about tie rods bing shortened and I'm running hydroboost just worried about clearance I guess I need to find out my wheel specs and get with you on that the arms I have now look exactly like the choppin block arms just not sure what they are they work fine but Way to close to my fenders the wheel is 24x10 bonspeed atoms not sure about offset and backspacing though
jeebus @ mmw   +1y
I thought that was you!
Burban is sick!
Taylor
groundedbigbody   +1y
Thanks for all the info Taylor I have made my mind up mmw arms are the ones I'm going with
1redchvy   +1y
Taylor is the man! Told you he'd take care of you Chad!
bigjon   +1y
I got choppin block arms and 35mm wheels24" and there I'd no way to drive let along turn slammed. Get the mmw arms there about the same price and you'll be much happier I'm thinking about ordering me a set. The trim job you need to do with the choppin blOck arms is rediculious but I guess I assumed the arm would fix that problem
