Removing stock lower ball joint 94 Sierra
we5pax@yahoo.com's avatar
i8nt2lo's avatar
i8nt2lo
Edited: 8/1/2011 9:46:25 PM by I8NT2LO
I'm assuming these are machine pressed in, so any suggestions on how the f to get these out? Or am I going to have to take the arms somewhere to get the old ones pressed out and the new ones pressed in? I'm just changing them out. Thanks for any info.
jeebus @ mmw's avatar
jeebus @ mmw
you will need the use of a hydraulic press, or a ball joint seperating press, you can buy at parts stores. Its like a c-clamp that has special "rings" that let you press the ball joint out.
its a serious pain in the ass, i suggest just paying your local muffler shop like 10$ to do it, if you dont have a press to use.
Taylor
i8nt2lo's avatar
i8nt2lo
Edited: 8/1/2011 10:04:57 PM by I8NT2LO
And will the same tool press the new ones in?
section8's avatar
section8
you can use it to press the new ones in also. most parts stores will rent them also. I know autozone and oreillys rents them.
TENONDUBS
MOST AUTO SHOPS WITH SO IT FOR YOU FAIRLY CHEAP IF YOU DROP THEM OFF
