Need some help from u-pull-it parts hunters
tuckinlugs05@yahoo.com's avatar
tuckinlugs06's avatar
tuckinlugs06
i am in the search for a alternator pigtail for a 2000 v6 eclipse ...none of the yards in the area have what i need ...so i need someone who is planing on going or goes offten to get one for me i will pay you for the parts and the labor to cut it off ... anyone that could help pm me thanks ..
gimp5561
ve you tryed the dealership i know with dodge they can order some reppari kit for wireing.
simple-pleasurez's avatar
simple-pleasurez
2000 is a little new for the u pull style wrecking yards. most i see are mid 90s
jblsuburban
look at 2000 up stratus coupes there the same cars not sure if sebrings ae but possibilty there too
tuckinlugs06
yeah i have looked at all the cars that use the same motor but the wiring harness on the alternator is different ...and the deal can get it but i dont have 300 to drop on the whole harness when i need 1 plug
jblsuburban
put up a pic of it and i'll see if any of my looms might have one on it
tre5's avatar
tre5
get your solder on and make you own. Even if the pins are small and inside the plug, you can usually still get a wire on it and solder it to the connector. Can't be too many wires on an alternator so it should be pretty easy. Then you can run whatever plug you want.
