Hey Guys, I have a 2007 Ford F-150 Supercrew 4x4 that is my daily driver/tow pig. The truck has a 6" Procomp lift and 35/12.50x18Procomp tires and rims. Out of the blue today the truck gets a wicked vibration in it at about 40-50 mph (60-70 kmh in Canada).I pulled over right away and checked to see if one of tires was going flat and check the drive shaft. Both checked out okay no flat and I crawled under the truck to check the drive shaft and u-joint some play(very minor maybe 1/16 of an inch) but nothing that seems odd. I'm at a loose as to what it is. Could a tire be seperating inside,front wheel bearings maybe u-joint not sure. The odd part is it happened for a bit then quit then started again. I know it's not the road as the road we where on was just paved. Thanks for any help guys.
cookiemonster13
i would check front hubs and front ball joints
bodydropped85
iwe solenoid probably. go on f150forums.com and search you will find a billion threads on this.
