Toyota suspension for a 620 Datsun?
seanburnley@gmail.com's avatar
seanb's avatar
seanb
Okay, I heard you can narrow a '92 Toyota's front suspension for a 620 Datsun. Can anyone confirm this or suggest a better option?
mindlissmetalfab's avatar
mindlissmetalfab
Im running a narrowed yota clip on my 68 datsun. no reason it wont work on a 620 as well.
kaoss's avatar
kaoss
You'll be glad you did. The best I could do with with my Datsun 620's king pin set up was to lay on 17's.
seanb's avatar
seanb
Okay, great! Is there any certain year that's better than another?
maz duh's avatar
maz duh
84-95 will all work for you. Look at the build thread for Seths toyota on here, he has pics of narrowing and installing a toy clip
dailydraggn's avatar
dailydraggn
i have the front clip from a 79 toyota under my 74 620 narrowed 4" to run my 18s. and rear end out of same truck narrowed 6"
seanb's avatar
seanb
Great! Would you change anything or do anything different? Appreciate all the info.
dailydraggn
Edited: 11/7/2011 2:03:58 PM by dailydraggn
all depends on what back space wheels you want to run. that is why i had to narrow 4" on the clip. made the upper arms and modded the lower triangulated and screw in ball joint and running 84+ stock spindles only cause i had them laying around because i planned to get can do arms but decided to do it myself. it lays on stock spindles with 225/30/20 but i built my truck to run the eagle alloy 203s since i found a rare set in an 18. i would do it again in a heartbeat way easier then the stock datsun stuff.
also i think the 84+ trucks are already 1" narrower so again just depends on your wheels and where you need them to fit.
