Mini Truckin General \  Undercoating Tubs
Undercoating Tubs
views 265
replies 2
Rob Clayhill   +1y
So after you took all the time and effort to weld in tubs for your dubs or larger, what type of undercoating did you coat the underside of them with? I seam sealed all of the welds to prevent rust and I also want to keep the noise down on the inside of the cabin. I was thinking of using some sort of Rhino Liner, would it work okay or do I need to use some sort of actual undercoat?
JTB   +1y
I used SEMs bed liner on the firewall,undercab & tubs on my truck. its a cheaper version of rhino liner but it works just as good, i tried a long time ago to used the mar hyde spray undercoating from advance auto & it took about 4 days to dry & did really work all that good, but yes the bed liner stuff works good or at least it has for me
truck action   +1y
On the top side in the engine bay,Line -X & used Herculiner in the bed,underside of all all welds seam sealer & than sprayed with rubberized undercoat.:BEERCHUG:
