Replacing a 4L60E tranny with a 700R4 in a 99 Tahoe? Anyone know?
clemsontravis14
I have a 99 Tahoe that I got at a deal with a bad 4L60E transmission. Does anyone know if I can put my newly rebuilt 700R4 in it? What problems will I have?
Anyone have a clue? I'm not finding much on google. I found a couple "no's" but they are on Yahoo answers. Has anyone here attempted it?
mooner's avatar
mooner
It is my understanding that the plugs are different. Housing are the same and some of the internals are different. I would get ahold of a good transmission shop and ask if it is possible. Let me know. My transmission I think is going out in my 99 c3500 and I have a fully built 700R4 that I was wanting to put in it.
low_blazer's avatar
low_blazer
It will bolt in, but that's it. The ECU will not control a 700r-4, and honestly, the 700r-4 is an inherently weaker trans. Also, you'll have to find some way to rig up the TV cable so it shifts properly, otherwise you'll burn it up in the first 50 miles. All in all, it's a bad idea. Find a good rebuilder and stick with the 4l60..
clemsontravis14
Won't a 700R4 work on a carburetored engine without any ECU?
low_blazer's avatar
low_blazer
Yeah, you need to wire up the lock-up for the torque converter, and properly set the TV cable...
NG
NC Goose
Could not agree more that this is a really bad idea. A 4L60 (and E) and 4L65E transmissions are next generation 700R4's. They are beefier and solve some of the issues that the 700R4 suffered from.
For the amount you would spend on on getting your 700R4 into your Tahoe, you could pick up a good used one from Craigslist or have the bad one rebuilt.
http://www.hotrodders.com/forum/700r4-vs-4l60e-171778.html - see the first to last post. Good information.
clemsontravis14
Teh 700R4 is out of a 91 1500. I think that that model tranny runs off of a TP sensor only and wiring the lockup for the torque converter will need to be done also.
I don't agree that it'll cost anywhere near what a tranny will cost to put this one in the Tahoe.
For some reason, Chevy went crazy that year with the 4L's and from what I have been reading, only a 4L from that same year (99) will work, so I am extremely limited in my Craigslist search.
clemsontravis14
I just noticed the link above.
Nothing in that forum sounds promising.
I might have a newly rebuilt 700R4 for sale.
clemsontravis14
If anyone is interested, I talked to a transmission shop and he didn't advise this. He said the 4L60E sends too much information back to the engine. It is in my best interest to rebuild what I have.
Thanks for the link above.
bagdb2200
The only thing the engine gets from the trans is speed from the vehicle speed sensor. The trans gets more info from the engine. It reads the Throttle Position Sensor and engine RPM so it knows engine speed and load.
You can use a 700r4, besides the TV cable, and wiring up a torque convertor lock up switch, you would need a VSS for the ECM and your speedo. I would stick with the 4L60E like others are saying though, if you can afford it. They are a little bit stronger. Plus it's a lot easier to tune shift points because it's all in the computer, you don't have to swap out springs.
