Mini Truckin General \  Bagging a 4door Blazer( HELP)??!!!!!!!!!!!
views 1867
replies 2
white92   +1y
I'm planning on bagging my 92 4door Blazer this summer. Can anyone tell me or point me in the right direction on what I should do as far as the rearend goes? The main struggle I'm having, is that if at all possible, I dont want to cut into the rear floor. It's sitting on 20inch Billet Specialties and it already has a C-notch, but the floor has not been cut on at this point. Do I need to lean toward doing a 2 link(bag on bar), triangulated 4link or what? Any reply would be greatly appreciated. Thanks!!
AVTekk   +1y
Edited: 1/24/2012 7:49:12 AM by AVTekk
If you just want to bag it, and not lay out, then you dont need to cut anything. But if you want to lay out theres no way to so it without cutting, esp on 20s. I did a truck on 18s and had to cut quite a bit but worked around the stock back seat and worked out really good. Heres the link, youll need to be a member to see the pics:
http://www.s10forum.com/forum/f125/bagged-4-door-1st-gen-blazer-325121/
The Unit   +1y
Like avtekk said you have to make the decision on how low you want to go, bottom line is on a 20 inch wheel if you want frame rails on the ground you have to cut the floor out and tranny tunnel for the driveshaft if you do it right you can still use the majority of your stock floor and back seat.
