what thickness metal for bed floor
tuckinlugs05@yahoo.com's avatar
tuckinlugs06's avatar
tuckinlugs06
is 14 gauge to thick ...its the only thickness i can get ...unless someone in pensacola knows where to get 4x8 sheets or 18gauge
maztang (ryan)'s avatar
maztang (ryan)
18 is the thickest I would go. 14 is going to make it extremely heavy. I will be using 20 on mine.
Draggin2hell's avatar
Draggin2hell
i used 16 gzauge on mine and its pretty heavy
35hundo's avatar
35hundo
Thinner the better for any bends and complex shapes. Even for a straight and square, 16ga is the absolute thickest, any thicker it becomes a lot more difficult to work with, plus useless weight.
tuckinlugs06
ok found a place that has 18 20 and 22 gauge sheets ...so what would be best for a bed that only is used for coolers for shows and chairs ...its gonna get linex
tre5's avatar
tre5
It depends on how much bracing you are going to put under the sheet metal. I have seen people use 1/8" with hardly any bracing at all (not the way I would recommend) and I have seen people use 20 ga. with 8" o.c. bracing. I usually go somewhere in between... 18 ga. sheet metal with 1" X 1" .083 bracing. I use a lot of diagonals in the bracing and try not to leave a void larger than 12"-16".
ven's avatar
ven
I prefer 16 gauge on the floor and 18-20 gauge on the sides. And definitely build a frame support for it to mount to. I typically use 1" square tube.
