Chevy/GMC Trucks \  C10 vs C30
C10 vs C30
views 3326
replies 2
artsar   +1y
I found a C30 I am thinking of building up. Its a single wheel and I was wondering if anyone knew if the front suspension is the same or not. I think I might get it and keep it 8 bolt, but just want to make sure the front can be dropped no problem. I know there are a lot of options out there for other front clips, but how similar is the front end to a C10?
jeebus @ mmw   +1y
Frame is 2" taller than the c10.
Suspension basics are same as C10
Cross member is same as C10
Spindles are different than C10
Good luck!
Taylor
maz duh   +1y
The suspension is similar in design but the C30 parts are heavier, a C10 front xmember will bolt in to a C30 if you wanna switch it up to 1/2 ton 5 lug. If you wanna get into a C30 drw I can set you up with an 86 3+3 that is in pretty decent shape and just begging to be made into a ride.
