Which bag cups?
Which bag cups?
CG
Camaro guy
I have a 85 camaro and I am wondering what bag cups to use.I have the lowers bolted in but need uppers and I really don't won't to buy Ridetechs front kit....Will a s10 upper cup work? I really need a cup with the hole access for my fittings.or any ideas..Thank you in advance.
Rob Clayhill's avatar
Rob Clayhill
If you have a welder than you could just buy the upper bag plates and get some 4-5" pipe and make your own. this way you will get the right size and not have to buy a kit.
CG
Camaro guy
Yes sir..thanks I was looking for the easy way I guess...
simply_brad's avatar
simply_brad
S10 uppers should work fine. The stock coil spring is the same diameter in S10's, Camaro's, Monte Carlo's, Cutlass' etc. The difference were in the length and load ratings. The shocks are all through the spring as well so the cup should bolt up as it would in an S10. GM didn't really stray away from too many things once they seen what worked.
