Chevy/GMC Trucks \  FULL SIZE ABS REMOVAL
views 961
replies 2
following 2
DEMON DAVE   +1y
ok i've got a 93 2500 suburban going to have issues with clearence on the ABS unit , I've seen someone on here (Ithink it was on here) who had details of removing the ABS system.any photos of how it was removed and / or parts required would help.
tre5   +1y
http://www.ebay.com/itm/Adjustable-Proportioning-Valve-With-Residual-Valve-Kit-/160804522945?pt=Motors_Car_Truck_Parts_Accessories&hash=item2570b24bc1&vxp=mtr
There you go...
You can get the kits for disc/ disc or disc/ drum. The PSI is different for disc and drum, so pay attention to that. Then it's just a matter of plumbing it into your system when you remove the ABS module. Make sure you have a good double flaring tool or you will have leaking issues.
DEMON DAVE   +1y
There you go...You can get the kits for disc/ disc or disc/ drum. The PSI is different for disc and drum, so pay attention to that. Then it's just a matter of plumbing it into your system when you remove the ABS module. Make sure you have a good double flaring tool or you will have leaking issues.
Thanks a lot , that looks like the ones i've seen used , again thanks.
