wiring troubles
devilx000@peoplepc.com's avatar
wiring troubles
devilx's avatar
devilx
Please help. I just wired a two pump set up with two batteries. The pump for the back working good but the pump for the front help hanging up. I have them both wired the same. What are some possibilities of the hangup?
shortrodeo
Im not sure what you mean by hanging up.... but if your saying when the pump spins it seems to not lift the truck and it acts like its locked up, check to see if you installed your check valves backwards.
Otherwise i think a better description of the issue would help a lot.
Miles
cookiemonster13's avatar
cookiemonster13
if you mean when you hit the switch is just keeps trying to lift the front then you have a bad solenoid
devilx's avatar
devilx
It would continue to spin after hitting the switch. I fixed it now. The block solenoids that I was told to use as book ends where the same ones that got it working properly. Now I just need to bleed to the lines
tre5's avatar
tre5
Those will not last 90% of the time. Hopefully you have better luck. What kind of solenoids did you try first that did not work properly. Any pics of your setup?
