Ford Trucks \  auto to 5 speed question
Ford Trucks Make Specific
views 588
replies 1
following 2
pipedreamer   +1y
Edited: 10/21/2012 8:11:25 PM by pipedreamer
hey there hows it going? i have a few questions about my 95 f-150. its a 5.8 h code (i think) extended cab flare side 2 wheel drive with the mark 3 package. Now its going to cost me about $3500 bucks to replace the turd it uses for a trans, but i was wondering if any one might now what it takes to convert it to a 5 speed. i know i need the trans and slave cylinder, the brake and clutch peddle. lines and what not but, do i need a different trans module, and do i need to use the trans cooler and fly wheel thats on it? and what other tid-bits do i need to do this? i have the tools and the lift. i had a 92 300 six with a 5 speed and i changed the clutch in it 2 times while i had it. so any info whould be AWSOME!
thanks guys
me
bodydropped85   +1y
im sure once you get a 5speed trans for a 351, everything should bolt up. you will need EVERYTHING from the donor truck, im sure a 5.0 should work. i would get the crossmember, starter everything.
