Toyota Trucks \  Disc brake conversion
Toyota Trucks Make Specific
views 1672
replies 5
tre5   +1y
This kit will work on Toyota trucks from 1983 to 2005, including Tacomas. It is meant to be an inexpensive disc brake conversion. The complete kit comes with everything you'll need to convert your drum to a 11" disc. I do not offer any other options for the kit. This kit does not have e-brake capabilities; however, there is another caliper that will fit this mount. You will have to have the cables made though as I do not offer them. Drilled and slotted rotors are also available, but I do not include those with this kit... remember, this is supposed to be an inexpensive kit.Check out the Tre5 Customs Facebook page for more info.https://www.facebook.com/media/set/?set=a.566058510080559.1073741825.117000834986331&type=1&notif_t=like
maz duh   +1y
Is it a solid or vented rotor?
tre5   +1y
It's vented.
maz duh   +1y
Kool beanz. Are the brackets available separate?
tre5   +1y
Yes sir.
sitnlow4life   +1y
Are you making brackets that are designed for the smaller mustang SVO rotor?
I am running this set up with the brakets made for a 4x4 yota for use with GM rotor.
The problem is that the pads do not completly make contact with the entire rotor.
The set up you have pictured looks like the same issue
