I keep blowing fuses
natesbizzz@yahoo.com's avatar
natesbizzz's avatar
natesbizzz
Not sure why this is happening but I keep blowing the fuse that runs to my battery from my compressors,Can anyone lead me in the right direction on what I should check? I am running a 8g wire right now.
truck action's avatar
truck action
If you are running relays,one for each compressor, try pulling one @ a time to isolate the compressors from one another! Or disconnect one compressor @ a time to see if one or both are where the problem is!!
cookiemonster13's avatar
cookiemonster13
there is a chance of your pressure switch is dead or the compressor is dying. as Gary said check them one at a time. what size fuse, relays, and compressors?
flnole78's avatar
flnole78
If I remember reading one time the leader hose on the compressor could be bad causing the comp to over work and blow the fuse.
http://www.streetsource.com/Groups/9/Topic/68216
DalyDrgr
Do they blow when you put a new fuse in (bad wire), or does it not blow until the compressors kick on (bad check valve)? Also, what Compressors and how large a fuse?
I just replaced my check valves because of this issue last week. Quite honestly, its a very common occurrence on Viairs (their pressure switches suck, no offense).
natesbizzz's avatar
natesbizzz
yah the valves were the problem I got new ones and i'm good to go. thanks everyone for the help!
natesbizzz's avatar
natesbizzz
oh yah I also has a bad fuse holder running to the battery from the compressors. its pushing 2 viair 380's, it was blowing 100amp fuse like nothing.
s10
last post by baha +1y
