99 Tacoma 2.4L 5spd
1 following
99 Tacoma 2.4L 5spd
jkesler89
I have a customer that would like to bag his Taco. I've done a lot of research but still have a few things I need cleared up. 1st everything I've read says the front needs to be Z'd to lay flat. I did read where Bobby Martin with Sadistic says he's never had to Z a yota or taco. My question is, what needs to be done to keep from doing a Z??!! 2nd up to what size wheel can you run without relocating the clutch resivor?? 3rd what needs to be done to the upper control arms or will the stock ones work without any modifications?? 4th on the rear suspension, by keeping the stock fuel tank in its stock location is a reverse link setup the best way to go?? Any info would be great. Thanks in advance.
