Back To Page - AUTOLOC
AUTOLOC \  Wanna ditch your Digital Gauges for something better?
AUTOLOC
views 958
replies 1
following 1
Ron_autoloc   +1y
Control your ride! Autoloc’s™ Air Command™ Air Bag Suspension Digital Controller Unit gives your complete control over your air bag suspension system. Featuring fully programmable settings and up to 8 user-defined presets, as well as built-in relay technology to control your air compressor, The Air Command™ gives you total management of your air bag system. Control each individual air bag, front and back separately, or all four bags at once! Viewing and adjusting your settings is a breeze thanks to the unit’s large LCD screen, which features backlit illumination for easy operation at night! All Air Command Systems come with detailed instructions and are backed by a limited lifetime warrantyDon't want to rewire your truck? No problem. Autoloc’s™ Air Command™ unit can use your existing digital gauge senders. Senders are available from Autoloc™ for $25 per sender.Autoloc’s™ Air Command™ is perfect for flush mounting in your center console or dash.Conceal It! Paint the inside of the Air Command’s™ clear case to match your interior, or mounting surface. The paint will never scratch or peel since the paint will be on the inside of the clear case.Autoloc’s™ Air Command™ Unit pricing starts off @ $350Order your Air Command™ Unit TODAY!Comparison Chart - Autoloc™ Air Command™ vs the CompetitionSEE THE Air Command™ IN ACTION!
Ron_autoloc   +1y
BUMP
