Back To Page - AUTOLOC
AUTOLOC \  Keep It Clean has more then you think , check it out !
AUTOLOC
views 950
replies 6
Ron_autoloc   +1y
Edited: 8/11/2010 4:28:40 PM by Ron_autoloc
All Keep It Clean™ Products:
Wire Systems
Wire Panel Systems
Wire Harness Kits
Sockets & Harnesses
Relay Sockets
Relay Sockets & Harness
Switch Socket & Harness
High Performance Electrical Parts
Alternators
Starters
Distributors
Coils
Lighting
LED Tape
License Plate Iluminated Bolts
LED Light Bulbs
LED Tail Lights
LED Flashers
Dome Light
Circuit Protection
Fuses
Circuit Breakers
Fuse Holders
Battery Disconnects
Heavy Duty Battery Disconnects
Direct Mount Battery Disconnects
Remote Battery Disconnects
Relays & Flashers
LED Flashers
Relays
Switches
All Switches
Rocker Switches
Lever Switches
Toggle Switches
Power Window Switches
Dimmer Switch
Ignition Switch
Brake Switch
Headlight Switch
Switch Cases & Frames
Billet Buttons
Illuminated
Non-Illuminated
Push Button Start Systems
Standard Push Button Start
Billet Push Button Start
Racing Switch Panels
Racing Panels
Racing Panels with Battery Disconnect
Wire
Power Wire
Speaker Wire
Wire Management
Modular Door Contacts
Modular Wire Separators
Door Looms
Wire Looms
Billet Firewall Wire Port Cover
Cable Ties
Adhesives
Electrical Tape
Duct Tape
Tools
Test Light
Wiring Terminals & Connectors
Butt Connectors
Spade Connectors
Ring Terminals
Quick Splice Connectors
Wire Taps
Bullet Connectors
Crimp Cap Connectors
Quick Disconnects
GM Column Connectors
Iginition Connectors
Dimmer Connectors
Headlight Connectors
VISIT KEEPITCLEANWIRING.COM FOR MORE INFORMATION ON INDIVIDUAL
PRODUCTS.
Uncle Fester   +1y
Hey Ron, I would like to get with you in the next few weeks about the door wire loom and what options you have for a door sill trim plate for Too Sloww.  Chat with you soon.
Ron_autoloc   +1y
Sure thing buddy ! Let me know.
tre5   +1y
Hey Ron, Do you have a harness for the LS1 motor? I am looking for a stand alone setup to run on a motor and tranny out of a 99 Firehawk. I am going to be starting a big project in about 2 months and would love to work with you on it. I am sure I will need a lot more than just a harness also, LOL.
Ron_autoloc   +1y
Hey Jeremy,  We have GM based wiring kits. Nothing that is plug and play. most kits are 2-3 hundred bucks (way better the the $1000 painless kit) .
tre5   +1y
alright thanks! I will get with you when I get started.
Ron_autoloc   +1y
good deal !
