Mazda 2.0L \  1980 Weber install- Do i need a fuel pressure regulator?
views 645
replies 2
following 2
tgregoryb2000   +1y
I am installing a new weber carb on my 1980 sundowner. I am trying to determine if i need a fuel pressure regulator on my fuel line to limit my fuel psi to the 3.0 specified by weber. . . Does anyone know if the old 1980 fuel pumps are too high pressure? The carb that was previously on this truck was an original nikki. Thanks for any advice!
sincitylocal   +1y
Since nobody else has replied, I will. I would install the Weber without it.The stock fuel pump isn't designed to supply a lot of pressure.
I doubt it will be a problem, but if you run into issues after install, consider a regulator at that point.
tgregoryb2000   +1y
I appreciate the advice sin!
