New guy here!!! Doing a 5 speed swap......
1 following
kaytbugsdad
I have a 1974 Courier (all stock except for a Weber carb), and was wondering...... Will the clutch out of the 4 speed work with the 5 speed transmission?? And if not, can I just swap the clutch fork and throwout bearing from the 4 speed to the 5 speed??? Any input would be greatly appreciated...... And the 5 speed came from a 1980 Mazda b2000 (2.0L, same block as mine).....
Post was last edited on Feb 21, 2016 12:42. Edited 1 time.
kaytbugsdad
Finding out more new stuff...... driveshaft needs to be shortened 4 inches...... Clutch will work with new trans, but I'll have to make a small plate for the trans mount to bolt to the crossmember.....
sincitylocal's avatar
sincitylocal
Customizing always presents stuff like this. The trans mount doesn't have to be very stout. I used 3/16 steel plate for mine... and that's for my V8 swap.
http://i427.photobucket.com/albums/pp357/SinCityLocal/TransmissionMount.jpg
Wait til you find your rpms are a lot less in 5th gear.
Post was last edited on Feb 23, 2016 03:20. Edited 1 time.
kaytbugsdad
No need to make a plate anymore..... modified the mount to where it will bolt to the crossmember without any further mods....... dropping the driveshaft off tomorrow!!!!
kaytbugsdad
So much for no more mods!!! I had to flip the crossmember over and weld a plate for the mount cuz the trans was hitting the tunnel!!!! Everything else went in smoothly..... Now just waiting till Thursday for the driveshaft to be done.....
Related Discussions in Mazda 1.8L
