Mazda 2.0L \  95 b2300
95 b2300
views 1066
replies 9
JGSR   +1y
Runs rough & misses when headlights on
Cusser   +1y
First thing I'd do would be to measure the voltage across the battery terminals at about 1000 rpms running with lights off, and then also running with lights on.
red1991   +1y
Sounds like ur alternater is bad
Cusser   +1y
"Sounds like ur alternater is bad"
That's why I strongly suggested he test. So he (and we) don;t have to guess. Personally, I'd get pissed if I bought parts to replace good ones !!! His post was a week ago, hope he's fixed the problem and not just jackin' around !
Post was last edited on May 24, 2016 02:05. This post has been edited 1 times.
JGSR   +1y
Alt is good now I'm going wire to wire checking. Gonna take for ever
red1991   +1y
Check battery terminals frame to ground connections and clean up ur plug to your alternator
mazdatweaker_2   +1y
Check for a dry cell in the battery. Lack of water will make the current pulsate.
mazdatweaker_2   +1y
I did some more research on your vehicle and if you haven't figured it out yet maybe you have a flaky daylight running module. https://www.google.com/?gws_rd=ssl#q=do+1995+b2300+mazdas+have+daylight+running+lights
Post was last edited on Jun 11, 2016 11:06. This post has been edited 1 times.
