Mazda Engine General \  Vapor lock on Mazda carburetors
views 760
replies 5
following 1
norwoodn   +1y
anybody experience vapor lock on a Carbureted vehicle? Specifically on a Mazda? What were your solutions?
I know the fuel is getting too hot. So reroute fuel lines seems like the answer.
Thanks in advance!
norwoodn   +1y
Well I put some aluminum foil around the easily accessible fuels lines near the fuel pump and engine, so it will dissipate any heat. And then hopefully the fuel won't turn into a gaseous state anymore.. Seems to work. Hopefully this is a safe procedure.
Cusser   +1y
I was going to suggest fiberglass insulation tape to wrap around.
I will tell you that I'm in Arizona desert and never have had such issues in 21 years with my 1988 B2200 with AC, back when I had the stock set up, or the last decade with my aftermarket Weber carb.
norwoodn   +1y
Well it's surging back and forth whenever it gets hot out. Haven't even checked how much fuel is being pumped. But I'm sure it's fuel delivery issue. Thanks anyhow cusser (:
The Lizard King   +1y
It happens to me every once in a while on a really hot day. I remove the gas filler cap to release the pressure of the built up gas, replace, and it usually starts right up.
