Mazda 2.2L \  Mazda b2300 A/C problem
views 829
replies 3
following 1
M&M   +1y
After I get off work I have to drive a few miles dowvn the road and then hear a clunk under the dash and then the air will start to blow cold and when idling the compressor cuts off and on but if I hold it to about 2000 rpm it stays on and blows cold but after I here the clunk sound it blows cold and cools off the truck fast what could be the problem
Post was last edited on Jun 18, 2016 04:06. This post has been edited 1 times.
mazdatweaker_2   +1y
You might have better luck posting your question here: http://www.ranger-forums.com
Cusser   +1y
My first thoughts would be to check the fan clutch for the radiator/condenser fan. Do a Google search on how to do that. Maybe bad fan clutch is causing high pressures and safety shut off. What you hear is the AC compressor clutch engaging, the magnetic clutch pulls in the hub so it starts pumping your refrigerant.
Second guess might be to measure/adjust the clutch gap.
Third would be to have a real AC shop measure refrigerant pressures, and recover and weigh the refrigerant, only real way to find out if there's been a refrigerant leak, as a leak and low pressures could also be a big part here.
I really think a REAL AC shop could readily troubleshoot this, AC work takes special tools and knowledge.
