Mazda Engine General \  Adding ATF to my oil, will it reduce smoking?
views 516
replies 6
following 1
NoiseBombz   +1y
And clean the valves etc. My truck burns oil, my supervisor suggested I add ATF to it. I also want to change my PCV valve maybe that'll help too, thoughts? Thanks I'm fairly new to the UF chassis.
sincitylocal   +1y
Nope. These engines all burn oil for the same reasons. If the factory(aftermarket units sometimes prove guilty) pcv valve doesn't help, you need to re-ring the pistons.
NoiseBombz   +1y
I appreciate the input I knew there was a reason I was on the fence about it, however, spending less than 10 dollars on a quart of ATF just to see what happens wouldn't hurt my wallet.
NoiseBombz   +1y
Also PCV valves are around ten dollars too so lol
mazdatweaker_2   +1y
You will know more if you do a compression test. If the truck motor has over 150k on it it might have worn out rings and ATF will wear them out quicker. You will need to do a "wet compression" test.
Cusser   +1y
My B2200 smoked and still had 165 psi in each cylinder. I re-did the head and did new pistons, rings, and connecting rods at 183K miles in 2011 and then had no smoke (did that without pulling the engine). Now at 210K.
