ecu reflash /remapping
1 following
phil80883
Has anyone had there later model g6 ecu tuned ? Is there anybody out there reflashing them just chasing a bit more power from mine
mazdatweaker_2
As long as you have an injected engine which has fuel mixture controlled by a feedback system like an O2 sensor you aren't likely to find any way to get past the limits of the feedback loop. Richer mixture at the O2 sensor = fuel trim (pulse width) at the injectors. Depending on how many miles are on your engine, you might be further ahead getting the injectors cleaned and replacing the O2 sensor.
Related Discussions in Mazda Engine Performance
