List of problems starting with the engine. Please help.
1 following
efeli26@ymail.com's avatar
Papo The B2200's avatar
Papo The B2200
1. At times my engine doesn't drop in rpm when I've stopped at a light until I blip the throttle which may drop it, or add to it. What the hell's going on there? Because I never had that issue up until last week
2. I've replaced every seal on here, & I'm still going through 5qts in about a week or two. Any ideas?
3. (Going back to the replaced seals), I'm still getting plumes of white smoke coming out of what's left of my exhaust when shifting, or stopped at a light. Is my head warped?
4. Why does my head irritatingly click when I first start it, & let it warm up, but then it tends to go away for the rest of the drive once I've hit 50mph?
------Now we get to brakes------
5. The most pressing issue right now is that my parking brake handle pulls way out of the slot almost reaching shifter now to park, if I attempt to pull it to it's original position, or a micrometer out of place from where it extends now it does not lock, & will roll forward. What broke, or happened to cause this, & how do I fix it?
6. With reference to 5, at times even when fully extended now it still doesn't lock up so I have to get on the brake, drop the parking brake, & pull it again up to 3 times before it finally locks... This happens usually once every 8 days. Any ideas why that's happening?
7. Has anyone done an all-around FC/FD brake conversion before? If so please send me links, & info because I just serviced the rear drums, & it was a pain in the ass trying to get my adapters of to deal with an even bigger pain in the ass to work on the drums...
-------------- Electrical --------------
8. Does anyone here make custom looms? I'm considering just getting a new loom altogether when I swap the motor to run bare essentials for racing use only. (which I intend to keep the original motor, & use it in a dune buggy.)
Please place the number you're answering first, followed by your answer just so I can keep track. (My mind's weird like that. Sorry.
mazdatweaker_2
Is your truck FI or carbureted? You could have either. Have you tried shutting off the engine and restarting it?
Maybe the rear crankshaft seal has gone bad and oil is leaking and getting slung against the bellhousing. Can yo put cardboard under the transmission to see if oil is dripping where the engine meets the transmission? If you recently replaced the clutch, maybe you didn't realize that the flywheel bolts will wick oil if you don't use a sealant on them.
White smoke is water. You might be able to re-torque the head gasket.
You could have a hydralic lifter that has collapsed, or maybe the mechanical lifters need to be adjusted if someone installed them in the past.
The e-brake cable may be streached, or the rear shoes have worn so far that the cable isn't pulling the shoes against the drums anymore.
Adjust the cable to remove any slack, after inspecting rear shoes for wear and clearance. They are manually adjusted through the backing plate.
mazdatweaker_2
Check the fuel pump if the engine is carbureted. It is located on the right side of engine (if in driver's seat) behind the carburetor. You will probably need to remove the air cleaner assembly to see it clearly. You can place a rag around the pump and start and run the engine to see if the rag gets soaked with oil. It is hard to see oil on the block where it drips, but you can throw corn starch against the block and see if any sticks; that is another way to test for a bad pump.
The seals in the pump go bad from when they wear out and they will leak a lot and run the engine out of oil.
