More Winter Work
1 following
gkellison46@gmail.com's avatar
More Winter Work
truck action's avatar
truck action
Just as the tile says,more small projects to do during this time.
First was fix the drivers side window that was going up all the way, replaced the window seal ,helped but pulling the regulator out & tightening up & using anti seize on all the moving parts solved the problem.
Next fix the emergency hood release, done!
Than find the problem with the head lights, have HID units & have a complete extra unit,so changed out & than a bulb change,fixed! Will send the bad unit in for replacement, Life time warranty.
Today will replace the power distribution block in the engine bay as the cover went missing & don't like having an open hot block.
Bolts?
W
last post by watatoy +1y
0
