Dually Engine \  350 mounts
350 mounts
Dually Engine Dually Tech
views 677
replies 2
following 2
str8ugly   +1y
ok heres the deal.... my truck originally came with the 454/th400 combo.... im going to be running a 350/XXXX trans ... now my question is, is will the brackets that are bolted to the xmember work with both the 454 and the 350? or will i need to search for some 350 xmember brackets?
monzter kuztomz   +1y
I'm almost positive the crossmember mount brackets are the same. I know for a fact the rubber mounts are different, and I think the the metal part of the mount that bolts to the engine are different too. Why don't you just use polyurethane bushings to make your own mounts & lower the engine in the engine compartment?
str8ugly   +1y
hell i can rebuild shit i just can't fab anything... also i just want something easy
