engine removal
engine removal
liltwin
The dually that I scored on last week has a blown motor and is locked up .So do I pull the motor and trans at the same time and do I remove the front to do it.My cherry picker doesn't lift that high.
someotherguy's avatar
someotherguy
Some people like it one way, others like it another. It's a hell of a lot easier IMO to get the torque converter engaged (or clutch aligned, if standard) and transmission bolted onto the engine with both of them out of the truck. Yeah pull the clip...keeps you from having to do that crazy angle to get the engine & trans out, even if your picker could go high enough. Gives you a lot more room to work.
If you weren't already thinking it, a trick I do to not make a huge transmission mess is to knock a yoke off the same type of driveshaft and use it like a tailshaft plug, run heavy zip ties or mechanic's wire through it and around the tail housing so it won't slip out.
Richard
liljlowrider's avatar
liljlowrider
if it was me id pull the front clip and pull them both together.
huskerdually
Ya what they said.
Related Discussions in Dually Engine
