Have a driveshaft question
F
conundrum
Don't know if this is the right area for a driveshaft question or not, and I did a search and did come up with an answer. The truck I picked up was without engine/trans, and I believe I found the front section of the driveshaft in the bed. A guy I work with has a rear section.
My question is, If I were to use the 350/700R4 combo from my 1/2 ton parts suburban, could I use the front section of the driveshaft from the suburban with a rear section for a 1 ton truck? Would the length be correct? What about the splines were the 2 sections come together, are they different for a 1/2 ton shaft and a 1 ton shaft?
Thanks for any help you guys can give me.
bdydrppup's avatar
bdydrppup
i know on mine i had 2 1 tons. a 75 std cab and a 85 crew cab and the shafts diameter was diff and the splines on the carrier bearing were also diff. now old gm auto trans are usually the same spline
Related Discussions in Dually Engine
