Oil Pressure
billylauriano@gmail.com's avatar
Oil Pressure
giovanni's avatar
giovanni
Ok on my way to work cold start oil psi runs between 60-80 for 10 mins. Drops to 37-40 on gas
On idel sits 20, Lately its been dropping past 20 after running for 45mins plus. Two times it wanted to throw the o mark n check gauge light.Hit gas light off.. No ticking or nothing, 124,000 .. Any help
lockone's avatar
lockone
Oil pickup tube may have small blockage or pump is just starting to wear out.
bk2life
go get a cheap oil gauge and install it to see if there is any problems. could be a bad sender.
but also be careful, my oil pump pick up tube fell off and toasted my 454..
BB
big bear
yea..i was gonna say pump proably going out.
someotherguy's avatar
someotherguy
Can't say I've seen pumps wear out, though the spring in them can get weak. I'd suspect the sender before anything else.
Richard
WL
wide load c-30
OP, did you ever get this figured out?
Related Discussions in Dually Engine
