Dually Suspension \  swapping front springs
Dually Suspension Dually Tech
views 1661
replies 8
trevor g   +1y
My plan is to eventually bag my truck, but for now to get it a little lower can i install front springs out of a 1/2 ton? Will this lower it? Will it ride better ( i don't haul or tow anything) In the back can i remove some leaf springs?
dragnasty   +1y
im not sure about the front srpings, but you shouldnt have a problem with pulling out a couple leafs and you could also install (or make) some drop shackles in the rear.
pig rig   +1y
hay I did this the springs wire diameter is smaller thay will not hold the weight I found this out 1200miles from the house in a wal-mart parking lot
physh1   +1y
Yup...1500 springs won't hold the weight. How are you dropped now? I want to ask that before I go into all the ways you could drop it...lol...
Cameron
pig rig   +1y
spindles&spring all belltech email me your phone # illcall ya
physh1   +1y
If you want to go an inch or so cutting half a coil rung is a possible solution. 1/2 a rung = ~1".
Any more than a 1" drop from cutting a coil will, IMHO, screw up the ride characteristics of any coil.
Cameron
pig rig   +1y
yea I cliped half a coil it went flat gradguile after a month or so
trevor g   +1y
Really? Thats not kool! I guess I will just bag it and install drop spindles.
pig rig   +1y
any thing worth doing is worth doing twice and youll be far happier the second time
