Dually Suspension \  wheel bearing torgue specs...
Dually Suspension Dually Tech
views 2779
replies 13
following 6
onefasthoagie   +1y
ok, i know with "normal" cars when you put the wheel bearing castle nut back on you finger tighten it as much as you can then go like 1/2 a turn and it's good, does it work the same for 1 tons as well???
guilty by design   +1y
I would imagine so.
dragnasty   +1y
pretty much
lockone   +1y
Thats a 10-4...kssh
pig rig   +1y
I thought you crank it down untill grease came out the back side?
maz89   +1y
Just tighten it with an impact til everything locks up ...... J/K don't do that.....
pig rig   +1y
Well it will be tight but hell on gas milage
lockone   +1y
3000 ft lbs will do it...
maz89   +1y
Yeah, if the hub starts smokin or the truck just snatchs off the road, just drive slower, you were probably just going too fast.....
pig rig   +1y
perfect
