Need stock stuff ...
hangslo
I am converting my truck (89 SCSB) to a dually, and am looking for any of the stock stuff any of you guys might have taken off your duallies. Specifically, upper and/or lower control arms, stock dually spindles, etc. I know I could go ahead and buy the lowered spindles, but if I could just get it converted on the cheap first, I can do that later. I have found a 10.5" 14 bolt that needs some work, but it is a steal at $100. I am looking to just convert it to a "stock" style dually first, and go ahead and include the body drop into the frame when I stretch it. I could also use a stock set of 16 inch wheels (and) tires as well.
lockone's avatar
lockone
I have it all on a truck back in the yard. I will check a price for all the stuff on Monday.
hangslo
sweeeeeet ... I should've known to call you first. BTW, did you ever find anything out about the cabs up there that I talked to you about a couple of months ago?
Also, the dually stuff should bolt up right to my mounts, correct?
maz89
lol, Lock's like the freakin' Chuck Norris of old dually parts.....
krewzlo's avatar
krewzlo
i got a set of 16" kmc slams with tires for sale
lockone's avatar
lockone
Yep it will all bolt up to your stuff. Both the cabs that I told you about last time we talked got f*cked up pretty bad in the tornadoes we had blow through in the last few weeks. The cab I had bought got a tree out right in the middle of it. So I am back on the hunt again for some more cabs. I will check on the suspension stuff tomorrow.
L8R
maz89
Damn that sucks man, was all the damage from the storms that hit when we were at lay'd out?
lockone's avatar
lockone
Thats the storms.....BASTARDS
lockone's avatar
lockone
On the stock suspesion stuff probably looking around 350 to 400 for both sides
