14 bolt numbers
phil@lowdowncustom.com's avatar
14 bolt numbers
balcar's avatar
balcar
How do you finger out the gear ratio on a corporate 14 bolt? Took the back cover and got some numbers, looked them up on that them there internet and it coudn't find anything.
Laterz
Phil
outlawcrewcab's avatar
outlawcrewcab
best way is to count number of teeth on ring gear and on pinion gear
balcar's avatar
balcar
LOL ring has 41, dunno on the pinion, guess i'll have to empty the fluid, LOL
lester622
put a lug nut on one of the studs and mark one side of the yolk, then turn it and count how many times the yolk makes a complete circle until the lug nut goes bac to the position it was in when u started ............................
so if the yolk turns four and and a half times to make the lug nut come bac to the spot where u started it it would be a 4:56 to 1 gear ratio ......... make sense?
pig rig's avatar
pig rig
number of teeth on your ring gear divided by the number of teeth on your pinion gear = gear ratio
lester622
or u could just do it my way and u wont have to count each individual teeth but its up to u ...............
balcar's avatar
balcar
I allready counted the teeth on the ring gear, witch is 41, how many different pinions are there for the 14 bolt? (as far as factory stuff)
balcar's avatar
balcar
then both sides would have to run perfectly the same, right?
