Dually Suspension \  bagging the front ???
Dually Suspension Dually Tech
views 2681
replies 11
following 5
nvrtolo4me   +1y
on the 73-91 1-tons what did you guys use to bag the front? i bagged my 87 1/2 surburban and i bought the plate&cup kit that Suicidedoors.com sells. would i use to same kit for the 1-ton or is there a different kit?
lockone   +1y
I use my own made cups. Never like the plate kits.
burntup   +1y
I have ekstinsive cups on the front of mine
nvrtolo4me   +1y
is it set up the same as a 1/2ton thou or is it going to be totally different
lockone   +1y
Same
trevor g   +1y
I'm using the kit from suicide doors on my 78 Seems to be working good. Got one side ready to go together when I get dropped spindles.
huskerdually   +1y
How do you like the kit? Going to do my 74 hopefully soon.
nvrtolo4me   +1y
i used the SD.com kit on my 86 burb and it seemed to work well. the only problem is drilling out the 1/2" holes in the crossmember i went thru about 6 bits and it took the better part of a day. oh and the kits doesn't come with the bolts so you will need to round up 8-1/2" grade 8 bolts and most place only stock like 1 or 2 at the most around here.
huskerdually   +1y
I used an aim kit on my 88 burb just wondering about how you liked the sd's kit. Lock what do you sell for the front of an 74.
lockone   +1y
Everything for the front of a 74
