my set up?
dibigtom@cox.net's avatar
my set up?
bigtom's avatar
bigtom
ok guys let me start by saying thank you for answering all my dumb questions.some forums not going to mention any names but have some real assholes on them.you guys have been real helpful in the past so ill get onto it....my rear set up now is bags on the 2-link bars would i be able to keep them and add two more on the bridge over the axle i will be towing a fifth wheel camper.it has re8 in it now so i would add two more.will it work and will it air up evenliy.i could throw up some pics.any input will help.
thanks again
bigtom
mazberrydelight's avatar
mazberrydelight
yesitwill work , but you have to remember that the bars on the barswill lift more then over axel so they will be overstreching the overaxel bags. i have 2600s on my bars and 3100s overaxel on my burb
maz89
Bingo! Couldn't of said it better myself!
huskerdually
I think it would be more productive to just put some of like the triple stack bags over the axle you can still get the lift but it wouldn't be so complicated. And if you put your slams on ebay or something it probably would cost the same.
bdydrped's avatar
bdydrped
another thing they wont fill at the same rate(which is just another way of saying what ^they said)
the easiest way to picture it is... over axel get 1:1, 1 inch of lift for everyinchthe bag inflates.... on the bar setup is more along 2.5or 3:1
aa taco chris's avatar
aa taco chris
I would also go with only 2 bags... Brandt had 4 rear bags on his frontier and it was a headache. Usually 4 bags just means afterthought in a setup... but if its easier and that much cheaper to each his own.
Good luck with the new truck Tommy!!! Glad to see you finally got a dually, and hows the t-shirt business coming??
krewzlo's avatar
krewzlo
I run the triple stacks behind the axle with a 4 link and rides better than sleeve bags and gets more than enough lift with my BD. Towing no problem, more than what the truck can handle. Costly but worth every penny imo!
bigtom's avatar
bigtom
thanks guys,i think ill go with the triple stacks on the axle.yo chris whats up sorry our deal fell threw bro i just needed some thing more stock in the drivetrain department.the shirts are going pretty well so far.looking forward to hooking up with you and dennis over the summer.
