Dually Suspension \  Mine is static dropped with.....
Dually Suspension Dually Tech
views 2080
replies 11
following 7
okdragger   +1y
2" drop springs for the front end of a s10 and shackles and hangers in the back with a few springs missing. It rides incredibly well with s10 springs in the front and doesn't bottom out. I am just runnning a small block.
liljlowrider   +1y
dragnasty   +1y
Im with lilj....lay off the bong homie....
okdragger   +1y
maybe I should refrase my topic.
I lowered my dually with s10 springs in the front and shackles and hangers in the back. How has every else static dropped there dually if at all?
watahyahknow   +1y
most of use here use bags and dropped spindles to lower
liljlowrider   +1y
never heard of anyone doing that.. when i was static drop i had a djm 5,7 kit. dont know how long those parts will hold up under that much weight.
low95xlt   +1y
yea i would use bell tech or djm, not sure if the s10 stuff can handle the weight issue of a 1 ton
okdragger   +1y
Friends are great aren't they? I'm gettin a 3/4 valve setup cheap as of this morning. I guess I don't have to worry about what to use on a static drop anymore.
pig rig   +1y
I was going to say your nut's the wire size that the s10 springs are wound out of is two small it can't hold the weight
