Dually Suspension \  Laying out a square body on 22" semis
Dually Suspension Dually Tech
views 3261
replies 17
following 10
1badgmc   +1y
I don't want to bodydrop it, just lay frame. I want to run a triangulated 4-link for the rear. I've read someone somewhere used a Suicide Doors triangulated rear setup. I've heard nothing but good about SD, is that the right way to go?
What other components are the best to run?
What valves? I was thinking about 1/2" lift and 3/8" dump.
What size bags front and rear? How much lift can I expect?
Will I need to cut out the fender tubs in the bed?
That's all I can think of right now. I'm sure I'll have more questions later.
lockone   +1y
Some use 4-links and some use 2 or 3-links it is all up to you. 3/8" valves are enough for a 1 ton truck. Bags are also another preference. Slam RE7s in the front and you can use the same in the rear or step up to the RE8s. Contitech, Firestone, and Airlift also have good products both bags and valves.
With the semis you will have to widen the fenders and do some small tubing inside of the bed depending on how big or small of a tire you run.
guilty by design   +1y
or get the townasty series wheels!
lockone   +1y
Townasty wheels are probably not going to be around much longer.
low95xlt   +1y
say it aint so,,,, first townasty is sold and then his wheels are discontinued, gettem while there hot boys
1badgmc   +1y
So what is done to make the Townasty wheels? Are the centers milled down to bring them in some or what?
I've got a good friend who owns a machine shop. Hell, I could probably just pick up a normal set of 22.5s and have him do all the work for me.
liljlowrider   +1y
just widen the fenders its so much fun.
lockone   +1y
Townasty wheels are just made with a different offset.
dragnasty   +1y
Glad you made it on here.
If you can find a set of Townasty's, that would be the way to go. Or you could run the bread truck rear end and the regular style semi wheels. I had contitech 2600#s in the front and heavy duty sleeve bags on the rear with a two link.
pig rig   +1y
sents we're on the wheel machine subject dose any one know how to machine them
