bags rubbing on cups
onefasthoagie
When the truck is aired all the way down what can i do to keep the damn bags from rubbing on the cups?? can i grind the lip off the cup????
1low1ton
what kind and what size bags are you running and where did the cups come from cause i have rs-82 or somethng like that slambags on the front of mine and they do not rub at all
liljlowrider's avatar
liljlowrider
yea hoagie more info please?? hell just take us some pics too
huskerdually
I like it when my bags rub on her c cups.
onefasthoagie
Re7's but i forget who's cups. when the bag collapses it hits the outter edge of the cup. you'd think the internal bump stops would stop that!!
krewzlo's avatar
krewzlo
Is the cup bigger in diameter than the top plate of the bag? If not than I don't have a clue of what is going on. It shouldn't be though. Can you take a picture??? The bag does have an internal bumpstop. It is designed to compress to 2.8 inches. So the endplates will actually sit in further than the rubber will when you totally compress it or be the same height. If you could physically squeeze the bag together in your hands you would see what I mean, but don't try it with a slam bag, you might bust a nut trying, firestones you can cuz the rubber is way more flexible.
If you can't take a picture can you draw us a picture of what you mean?
balcar's avatar
balcar
this is a problem on larger trucks. The problem with slams is that they don't have a built in roll over. Firestone, conitech bags both have it built in. What I did when I went with slam bags is I used air lift roll over plates.
Thanks
Phil
1low1ton
without seeing it sounds to me like you need smaller diameter cups
onefasthoagie
what exactly is an air lift roll over plate? are you makin that up? lol
1low1ton
its the plates that come with airlift bags athey go above and below the bags between the cups and are flat and smooth so the bag will touch them and nothing else if you want some i think i have some spares
