I have a set of 22.5" alcoas I bought pretty resonably, and I have a couple of questions..
What companies if any, will mill them down for me?
Also I have 4 brand new nitto 555 285/35/22 tires, will they work?
I thinking of running 22" outers in the back and 16" steels on the inside for towing purposes.
any info is greatly appreciated..
pig rig
I heard these guys do a lot of semi wheels and their kinda close to you
kainzien
thanks for the info..
I've been searching and there is a company in Houston called dima wheels:
I've e-mailed them just waiting on a reply..
I think they are members on here also.
low95xlt
i think or believe they are runnin 265 40's or even 35's on there 22's
kainzien
Thanks, I compared the two sizes:
285/35/22-----------285/35-22
285/35/22 Section Width: 11.22 in 285 mm
265-35-22 -Section Width: 10.43 in 265 mm
Rim Diameter: - -
Rim Diameter: 22 in 558.8 mm-
Rim Width Range:
Rim Width Range: 9.5 - 11 in -Rim Width Range: 9 - 10.5 in
Overall Diameter: - -
Overall Diameter: 29.85 in 758.19 mm-Overall Diameter: 29.30 in 744.22 mm
Sidewall Height: - -
Sidewall Height: 3.92 in 99.568 mm-Sidewall Height: 3.65 in 92.71 mm
Radius: - -
Radius: 14.92 in 378.96 mm -Radius: 14.65 in 372.11 mm
Circumference: - -
Circumference: 93.77 in 2381.7 mm -Circumference: 92.04 in 2337.8 mm
so maybe they will work...
pig rig
the 265 35'sare what I just put on mine
1fastlx
they will work 235/75/16 on the inside pm lockone about the milling we can fix you up!
lockone
I can mill the wheels for you. I will pm you the prices.
The 285/35/22s will work fine and for the inside wheel you will need a 235/75/16.
