Dually Suspension \  lenght of 2 link bars
Dually Suspension Dually Tech
views 956
replies 3
orangelowmazdawg   +1y
can anyone tell me the length for the 2 link bar on an 88 (obs) crewcab dually? i have a set of lower weld on tabs for the rearend. i am planning on running a wishbone upper link. also how tall will my notch need to be to be able to lay with a 22 or 24" wheel. going to use the truck to pull a gooseneck trailer. what size tire would work the best for pulling the gooseneck trailer. (22"&24")
diabolic kustoms   +1y
well you need to know what tire size for the notch. But for 22's I use a 10" notch and even it up with the bottom of the frame. But that is with a 30 series tire. There are people on here that may be able to answer this better then I. As for the links.. well measure from your tab to your leaf spring hanger.(at ride height)
rhmdually   +1y
mine is a new body style but my notch is only 6.5" and its set up to clear a 22 safely. idk if that helps or not.
ec_dually   +1y
i ahve a 2000 obs dually and my link bears were 48 inches long, but i ran mine past the rear end just a lil bit...
